Configures the keepalive timer and hold timer values for a peer group and all the neighbors of the peer group.
| peer-group-name | Specifies a peer group. |
| keep-alive seconds | Specifies a keepalive time in seconds. Range is 0 to 21845. |
| hold-time seconds | Specifies a hold-time in seconds. Range is 0 and 3 to 65535. |
N/A.
This command applies to the current VR or VRF context.
Changes made to the parameters of a peer group are applied to all neighbors in the peer group.
After you enter this command, the switch automatically disables and enables all neighbors in the peer group before the change takes effect.
The following command configures the keepalive timer and hold timer values for the peer group outer and its neighbors:
configure bgp peer-group outer timer keep-alive 30 hold-time 90
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
